Well at 25k the best 1200p will be Asus PB248Q. It's an IPS panel.
For budget 1200p, Dell U2412M. Which I use, it's a decent monitor. Price is around 18-19k.
For VA panel, I will definitely recommend the Samsung S27C750P, you can guess from the model no. it's a 27" model. You can get the 24" of the same at much lower cost if you want.
That's it. Need IPS at 25k? Go for the Asus. Need IPS at budget? Go for the Dell. Need VA? Go for the Samsung.
I personally will recommend VA anytime over IPS. You didn't say that you will do any photography related work, so basically IPS makes no sense. The Samsung one is however 1080p, while the Asus and the Dell are 1200p. Technically 1200p is 30.5% more PPI than 1080p, thus more future proof. But as gaming is not your main priority either of these should serve you well for at least 3 years.
