System Crashes Unexpectedly - URGENT HELP REQUIRED
naveen_nic
Hi all,
My system crashes unexpectedly, i cant figure out the problem.
Configuration: PIII 1.13Ghz,
810 Mother Board,
256MB RAM,
40 GB HDD,
Windows 2K prof SP4.
Norton AV 2003 (virus defn up to date)
System crashes while using IE, or applications like Photoshop.
While navigating web pages suddenly system crashes (esp yahoo mail or other web pages with many pictures)
Pl help on this issue..
regards
naveen.
[/b]
swatkat
Does it give any error message? Also, does the Photoshop crash while using it Safe Mode? And, also try this, open Internet Explorer, go to Tools> Interent Options. Here click "Advanced" tab, and UNCHECK the option "Enable third party browser extension", and click "Apply". Now check with the web pages, and post back whether it crashes or not.
N
naveen_nic
Thanks swatKat for your response.
No error messages.. Scan disc checks for errors after restart.. Some files in Temp internet folder is truncated aft scan disc.
I ll check photoshop in safe mode.
As u said I UNCHEKED the option.
Will post the outcome.
swatkat
Hmm...time to clean up some junk, download CCleaner and install it.
Then run it, click "Options" button and here go to "Settings" tab and uncheck the option "Only delete files in Windows Temp folder older than 48 hours". Click OK to exit from the Options. Finally click "Run Cleaner".
