Slow Internet speed when connected using Ethernet cable
shivamdhar532
I am getting slow internet speed when connected using a Ethernet cable but getting faster internet speed when connected through wifi .How is that possible(I am supposed to get a faster internet speed through a wired connection as compared to wireless)??
Sent from my Micromax A106 using Tapatalk
kg11sgbg
Hey @dashing.sujay & @whitestar_999, Friends,do you have anything to say about:--->
just now my Speed Test Results :--->
*www.speedtest.net/result/5724803265.png
kg11sgbg
I can only say speed is slow. btw don't hijack the thread.
Sorry for the re-presentation(thread Hijacking).
I mean could you mention about the SNR and Line Attenuation from the image I posted of my Netgear D1500 ADSL2+ modem/router?
My Telephone wire was replaced fully on July this year(brand new wire).
The Netgear D1500 ADSL2+ Modem/Router is functioning fully O.K.
Any remedies???
chris
How did you tested speed ? LAN cards have multiple mods, like half/full duplex, this can affect LAN speed, not internet speed.
parteekv
Hi Shivam, There might be some issue in your LAN cable or in the port in which you are connecting your LAN cable. Because i also had the same issue and my system was under warranty and now it works very well.
