[Query] Seagate RMA - Mumbai : Need help and advice on procedure.
How is the SEAGATE RMA experience?
  • Can't say (if you have other resources,please suggest)
    Votes: 0 0.0%
  • Total voters
    3
  • Poll closed .
Phenomenal
Hello,
I have a Seagate ST3500418AS 500GB (purchased in 2009,under warranty) drive from Mumabi (Lammy Road) and Hard Disk Sentinel shows that it has only 9% life left.
It says there are 2000+ Bad Sectors on the disk surface and also it warns about the reallocated sector count.
Here is the exact message :
Can I get this drive RMA'ed ?
I plan to contact my reseller (Lammy Road Shop) as I have the proper VAT bill alongwith the serial number and original static cover.
I heard Seagate gives a REFURBISHED drive and not a new one,is true?
What about the warranty on the new drive?
I am scared that only 14 days are left!
Backing up all the data now!
Also if it's not required then what is the significance of those errors and how can I fix them?
Please advice and also comment about your Seagate RMA experiences.
THANK YOU :)
get seatols fro Dos -- write it on a CD - boot your pc suing it and run along scan and post the report here.
doomgiver
Warframe
the guys accepted my disk and gave me a "refurbished" one. it looked new, and came in sealed package, but they called it refurbished.
the only caveat being that the hdd must not be tampered with/have physical signs of damage.
done about 2 weeks ago in nehru place, delhi
