Hello Guys,
Digit forum had helped me with getting a great graphics card in the year 2008. I was very happy with the decision on buying Sapphire HD 4870 512MB GDDR5 PCI-E. It has served me very well till now
Suddenly since last 2 days I have started getting a problem.
1) System boots up fine till the Windows 7 login.
2) As soon as I see the Windows Login screen, I also start seeing the white squares on half the screen or sometime black lines
3) I removed the graphics card cleaned the dust and re-inserted the card. It worked for around 2 hours and then again the same problem
4) Sometimes it goes so bad that all the the screens fills with white squares and red lines. The screen then blinks and then the white squares increases and also red vertical lines in background.
I tried removing the data cable from back and inserted into the internal graphics card slot and it works just fine. I can see that the temperature doesn't increase much..not more than 65 degrees.
Any idea as what I can do further? Can I get it to any service center in Pune? It bought it in the year 2008, so no longer under warranty. Please help me guys!!!!!!
Common Guys please help me out. 54 view but no reply
