Repeated motherboard failure problem ..somebody quickly help me out.
moinak21
Sir I am a Digit subcriber..and I am experiencing a serious problem ... Actually I dont know what is the actual Problem behind the problem which I am experiencing..so pls tell me the reason for the problem and also tell me the measures to control it so that it does not occur any time in future because this had happened twice.they gave
My Configuration : Intel Core 2 Duo processor,ASUS P5N-MX Motherboad(Inbuild graphics with NVidia 7050),Tamkor 1GB DD2 RAM,ASUS DVD Writer,500 GB Seagate HHD (SATA)
My Problem : One day I was Playing FIFA 09..in my PC.Suddenly my pc got restarted (which never used to happend and i played fifa alot of times a day)and then I could here a continuous beep noise....I thought there was I problem with my RAM..so I went to a Hardware engineer he tested and said that my Motherboard was damaged...so I went to ASUS Service Center and they too discoverd and tested and replied that my motherboard was damaged....Since my motherboard was in warranty they in turn gave the same motherboard for use(ASUS P5N-MX)but again a few days before I was again playing FIFA 09(appoximate it happened 30 days after
I bought the motherboard form service center)and unlikily the same thing happened and my mother board got restarted and continous beep sound and I cannot start the computer I used different RaMs but the results was the same ...Sir pls tell me the reason for this condition and why it happened ? Tell me some measures to control in future..Sir rlp as fast as possible...
Thanks.
thetechfreak
Legend Never Ends
what Power Supply Unit do you have? That might be culprit.
and yes try to leave Fifa 09 because if it happens again I doubt how many more motherboards the centre will give you.
Also, you're problem may be due to overheating.
MatchBoxx
the m0nk who sold his PC!
Looking at his configuration, i think he might be using generic local PSU that comes bundled with the cabinet.... @asingh, @thetechfreak
btw, what is "tamkor"? Never heard of that company!
thetechfreak
Legend Never Ends
That must br the reason.As most people completely ignore the importance of PSU. I suggest you to get a proper PSU like=
FSP Saga II 500w @ Rs.2200
Tech&ME
Banned
I think he also needs to replace the RAM with some good brand.
Also he should upgrade the RAM to atleast 2GB minimum.
M
moinak21
Thank u all of u, now I want 2 buy a new cheap DDR3 motherboard.pls suggest me some names along with the prices.
Piyush
Lanaya
i think in order to use DDR3 rams you'll need a new processor too because the motherboard suitable for core 2 duo series are all DDR2 motherboards
do you want to change the processor too?
thetechfreak
Legend Never Ends
Then there is nothing you can do. The game may have a virus so its best to get rid of it and get a alternate versions.
Faun
Wahahaha~!
Here is the mobo core2duo with DDR3 support
ASUSTeK Computer Inc. - Motherboards- ASUS P5QC
You can find more either by googling or by contacting websites of respective mobo brands.
Account has been suspended - H-Sphere
M
moinak21
in both the cases,my windows got crashed and i have to reinstall windows 7 again.so whats the problem!!! pls tell me the reason for this problem!
thetechfreak
Legend Never Ends
Well Moinak, there isnt enough information for us to tell what the problem EXAXCTly is. The game might have a virus too
M
moinak21
But why is windows gettin crashed???
suggest me some mothrboards name....my budget is very less i.e less than 3000
ddr3,
skeletor
GIGABYTE - Motherboard - Socket 775 - GA-G41M-Combo (rev. 1.3)
Motherboard with nVidia graphics + DDR3 memory support for Intel Core 2 Duo? As far as I know, there isn't any.
