rediffmail problem in xp..help
hi..guys.
i hav win xp n win 98 on my machine ...problem is that whenever i try to login to rediff mail from my xp ...error messege come"your login has expired" while this site is working very fine in win98 ....this is the main problem for me as i usually use xp...n i had to use 98 just to cheak my mails..pls help me ...i will be very thankfull to you. :cry:
Hexus
Banned
- Clear your cookies, or eat them if you want but dont leave it there for long.
- Clear your temporary files, they are known as temporary but they are'nt
- Check for viruses & Trojans, these insects have an amazing ability to survive.
Tech&ME
Banned
well! This is a common problem with rediffmail. Actually if u have installed SP2 you will most probably get this error. Nothing to worry about though, Rediffmail actually 'sees' that u are running Windows XP don't be surprised, it possible to make websites such that they collect information about the usage pattern and what versions of the os is running on the surfers computer. Just make some changes to IE or switch to FireFox.... simple.
N
nipun_the_gr8
Guest
I didn't have prblms after installin' win xp sp1 or sp2 with rediff.........
