problem with xp boot up "operating system not found"
prakashr85
installed norton ghost 2k and i clone a 160 gb hard disk with mine after system restarts error message came like this "operating system not found"
pritamonline
I had faced same problem "operating system not found" after creating image for the first time with Norton ghost 2003. I had selected my c drive for creating image and it would be saved on d drive. After clicking on few next buttons, it asked me to restart. And then XP never loaded !! :-( .
I had re-installed the WinXp OS SP2
Tip: Always copy important files/folder to some other drive before creating image!
Pritam
ravi_9793
TechTin.com
As a old member of the forum, I must say.......
"You dont need to add your site link after your each post. Avoid this habit"
I think you were once warned also by some moderator.
kalpik
In Pursuit of "Happyness"
Yes, i have already issued a warning to him.
@Pritam. This is your last chance. You will most definitely face a ban if i catch you doing the same thing again.
Renny
Enter recovery console in XP setup,
There type "fixmbr" and "fixboot" (Without quotes).
