Hi to all.
I do not know where exactly to post this problem. Since its mainly related to the USB ports, I'm posting it under the Motherboard category.
My PC configuration is as follows
Intel DG31PR Motherboard
Intel c2D 2.4Ghz Processor
2GB + 1GB Corsair XMS2 RAM
2 x 250GB Hitachi Deskstar HDD
LG DVD Writer
Mercury 450W SMPS
Videocon Integra 19inch monitor
There are a few problems. The latest and the most important one being the problem with USB ports. At times, my USB ports doesnt work. I plugin my USB device, mainly IDEA NETSETTER and PENDRIVES. They work sometimes and sometimes they dont. The system detects USB devices sometimes, but they keep on getting connected and disconnected continuously, as in a loop, without any loose connection.
I'm not able to use any USB hub also. The USB hub gets recognized, but the USB device I plug in to it is not read or detected.
Both these problems mostly occurs while using windows. Almost 75% times, its a failure. When I use Ubuntu, probability of devices getting detected is more, but still it fails.
Another problem is with the Hard Disc. I have two 250GB hard discs as I mentioned earlier with the configuration, but one hard disc is not read at times(always the same one) and sometimes, system doesnt even boot. If I restart after sometime, the hard disc may be read(still not sure though). This problem exists in both the OSes.
I use a Videocon Integra 19inch Monitor. When I use Ubuntu, I'm not getting resolutions more than 1024x768. My monitor supports resolution upto 1440x900.
I dont know what to do,with any of these problems.. In a complete dilemma. Help me out please guys.
also, one more thing to add - I purchased this motherboard and Processor in 2008 - June-July
Processor is c2D e4600 2.4ghz. OS is Windows 7 Ultimate 32 bit and Ubuntu 11.04
LG DVD Writer
Mercury 450W SMPS
