Yoda
my PC Config.
AMD Athlon 2600+ Barton Core
ASUS A7N8X-E Deluxe
512MB DDR RAM
Gigabyte ATI Radeon 9600XT (128MB DDR)
Samsung 15' Monitor
Samsung 80GB HDD (7200 rpm)
Sony DVD-ROM
Samsung CD-RW
Modem
UPS (Local Brand)
OS -- Windows XP Professional (with SP1)
DirectX 9.0b
The drivers I installed was ATI CATALYST Windows XP 4.10. Full Package.
ATI Catalyst Drivers for Windows 2000/XP 4.10
ATi Catalyst Control Panel 6.14.10.5125
A few days back I installed the ATI Control Center or Panel(I don't remember exactly), the installation was succesful but there was a error message, but i was able to access it.
Then the next day I got a friend Hard Disk and installed it as slave, after starting the PC the system stopped at the word "Windows Xp Professional" then i started the pc in Safe Mode the desktop came but the screen looked horrible. There were many vertical lines and I couldn't see properly. I some copied and after removing the slave HDD everything was fine. Windows started normally.
Day before yesterday i got FIFA 2005 and I installed. And my brother changed some settings from 2x to 8x in ATI Control Panel and it showed some inscrease in resolution 1240 x ..... (I don't remember). And the game worked fine. Yesterday night I installed Clone CD 5 (it worked fine) and after some time my brother was playing FIFA 2005 and while palying,
suddenly the monitor went OFF and the yellow LED in the monitor was blinking. From there our problem started....
I restarted the PC and the same thing happened. Then I went into the Safe Mode and the desktop came but It was horrible to see. There was a lot of thick vertical lines(white,green...) all over the screen.
Then in the Desktop-->rightClick-->Properties the resolution was 640x480.
(32bit -- Highest). I tried to find that ATI control panel (for reducing from 8X to 2X) but it was not there.
Then I unistalled all the ATI drivers, but couldn't uninstall the ATI Control Center or Panel.
Then I saw the new Hardware found, I installed the drivers from the CD which I got from my Graphics Card. It asked me to restart but the same problem was there. Then I enter the OS throught Safe mode and installed
ATI CATALYST Windows XP 4.10. But the same problem was there. I tried uninstalling Clone CD but no use and Unfortunately I haven't saved any Restore Points and even if I there is a restore point it would be few days back and if i restore I will lose many of my data.
What will be the problem.
Is anything wrong with my GrahicsCard or Motherboard or any hardware.
or is my drivers making the problems.
Just now I saw in the ATi website and it says...
CATALYST Windows XP 4.10 - Driver Download
Instructions:
Before you start, please read the ATI Driver and Software Installation Instructions.
Installing a new driver is only recommended if you are having issues with your ATI product, including those mentioned in the "Fixed in this driver".
For more details, please review the RELEASE NOTES.
Notes:
ATI recommends Windows XP Service Pack 2 or higher to be installed.
High Speed download is a single package for DSL and Cable modem users.
For dial-up users the driver is divided into multiple components for easier download experience.
The drivers below supports 24 languages.
* The CATALYST Control Center is available in English only at this time. Additional languages will be available in future updates.
in ATI i found this
I found a table. SInce I don't know how to paste a image here, i give u the link
*www.ati.com/support/drivers/winxp/...&prod=productsXPdriver&submit.x=13&submit.y=7
For previous version drivers
which comes with the message,
The following previous display driver versions are offered as a courtesy to customers looking for a specific driver release.
These driver releases are no longer supported.
Not all RADEON drivers support all configurations. Please read the driver descriptions carefully.
Current ATI Multimedia Center and DVD Player software may not function with some of these driver versions
*www.ati.com/support/products/radeonwinxppreviousdrivers.html
and ATi says....
to install all these
Display Driver,
Control Panel,
CATALYST Control Center,
WDM Capture driver
it says i must have....
1 package
Supported on the RADEON 9500, RADEON 9600, RADEON 9700, RADEON 9800, RADEON X300, RADEON X600, RADEON X700 or RADEON X800 Series of products.
Note you must have Microsoft’s .NET Version 1.1 Framework installed
I don't have Microsoft’s .NET Version 1.1 Framework installed in my PC.
or shall I install previous version drivers.
Display Driver Version
CATALYSTâ„¢ 4.9
Driver Build 6.14.10.6476
8-051-040825a-017633c
or Catalyst 4.8
What all should I have.
Display Driver
Control Panel
WDM Capture driver
or the whole package.
Download ATI Catalyst Drivers for Windows 2000/XP 4.10
Download ATi Catalyst Control Panel 6.14.10.5125
I'm soory to write a very long post But i have to solve the problem and you are the only guys who can help me out.
What I should i do and give a solution guys
Thanx in Anticipation
Arsenal.
my PC Config.
ASUS A7N8X-E Deluxe
512MB DDR RAM
Samsung 15' Monitor
Sony DVD-ROM
Samsung CD-RW
Modem
UPS (Local Brand)
DirectX 9.0b
Instructions:
Notes:
in ATI i found this
and ATi says....
Display Driver,
Control Panel,
WDM Capture driver
1 package
CATALYSTâ„¢ 4.9
or Catalyst 4.8
Display Driver
Control Panel
WDM Capture driver
Arsenal.
