I was recently installing Fedora Core 5, and got this error after the anaconda starts to install after getting the language options. It says that the hda is not initialised. then asks if it shud delete all data
My FC5 bootin process is damn slow and after bootin it takes nearly 5 min. for getting start for an application.IS it a bug or hardware incompatabality.
but same things on RHEL4 works smoothly.So stopped using Fedora.
