problem regarding display using gfx card.....
anonymous 1
i hav a vry old pc running on pentium d, with 2gb ram and 160gb hard disk.
i installed an ati 5450 gfx card arnd year n a half back. evrything ws working well n fyn until wen my ups (now i'v changed it) started failing with its power back up and den d prob started. back den, wen i used to start my pc with gfx card installed, it used to boot bt latr said no signal. i used to switch it off directly n restart again. aftr trying several tyms display used to come n den worked fyn. it had to repeat this procedure wenever d pc remained switch off for long tym.
but from few days back d display goes completely blank n evn d pc doesnt boot wit gfx installed jus d logo screen comesn den blank. wen i remove d gfx card n use my onboard vga port it works.
fyn, i thot my gfx card blew off but no, tried on ma frns pc, it workd.
flashed my bios by removing d cmos battery for abt an hour n putting it back again but of no use....
i dont knw wts d prob...... help me with it
do provide me with sol......
thnk u in advance..!!
