kumarn_2004
Hi Guys,
· Windows XP Home Edition .I install some softwares and uninstall them. After uninstalling, I face many problems with my Computer like Computer does not work properly and the like. Are there any proper procedures to install and uninstall the softwares? How to do all? Your step-by-step procedures?
· I am using Diskeeper Home (version 9.0.538.0). It stops working in the middle of the defragment. How to solve it or can you recommend any completely free and good software for the purpose out of your experience?
Cool G5
what do u mean by 'computer does not work properly'?Plz give the exact problems you are facing.Regarding uninstallation,remove them from add/remove program.There is also a good freeware Zsoft uninstaller for removing programs.
K
kumarn_2004
HI Mr.Cool G5,
Comuputer speed becomes very slower or sometimes hangs.
