napster007
hello,
i have been facing problems installing windows xp on my compaq c300 laptop. when i boot up with the CD it loads the necessary files and stuff and in the first option menu where it asks if i want to install or repair and stuff, when i select to install the XP, it says that the "No hard disks have been found connected to the laptop". this problem had occured before but at that time it got solved when i disabled the 'Sata native support' in the BIOS. but now it makes no diference wether i turn it on or off.
please help me with this problem, i need to get my laptop running ASAP.
regards.
regards.
