Problem in front panel
avichandana20000
I am having CM ELITE 310 and am using for the last one and half years. every thing is fine. But the audio jack in the FRONT PANEL is not working. But the USB ports are working fine.
Can I change only the FRONT PANEL ?
saswat23
how can u change the front panel dude. Its not of any use.
Check if the cable of the front audio coonector is plugged properly inside the cabby. Else try and change the cable, it might be faulty.
But are ur audio connectors at the back working fine..???
avichandana20000
avichandana20000
Back panel is working absolutely fine.
i am asking whether this (refer attachment) is available ?
Skud
Was it working earlier? Either a loose connection or some driver settings need to be changed provided there are no physical damage.
avichandana20000
avichandana20000
it was working earlier. actually when i insert the jack somtimes a very thin sound comes and sometimes no sound is there at all.
i think it is a case of loose connection.
