Problem Ejecting USB Mass Storage Device
sanny16
Whenever i try to eject my 2 tb WD portable hdd, my pc gives this error: "Windows can't stop your 'Generic volume' device because it is in use. Close any programs or windows that might be using the device, and then try again later."
I can't find any program that is using the wd hdd. Is there any fix for this?
lywyre
If you were playing any media files in iTunes/WinAmp or any such programs you may have to close those before removing you HD (or a pdf/doc in which case you have to close the pdf reader/ word).
srkmish
Download unlocker and you can see what is keeping lock on your hard drive. Its a must have windows program for me.
gameranand
Living to Play
If its happening every time even when you are not using any files on that Mass storage then its a Virus. Do a complete scan of your system, preferably boot scan.
sanny16
sanny16
how do i run a boot scan? is there any app for that? I have microsoft essential on my vista.
rijinpk1
you can also use avira boot disk and create a bootable disk and boot from usb. scan whole computer.
