Power Problem!!!
The Day Walker!
Pals,
since some time, i am facing a strange problem.
when every my pc comes under load, (playing games, or loading lot of files in photoshop)
my ups starts to beep continuously. with red light. (apc 600 ups)
i have changed my ups to new apc 600 upa and have also changed my smps,, still the problem persists,...
thou i never had the problem previously. after a power fluctuation at my place,, the problem has started...
but still i have changed both the components still the problem persists.
needed help in rectifying the problem.
T
The Day Walker!
RIG:
AMD Phenom 2 X6 - 1055T (O.C. 3.71GHz)
CM Hyper 212+
Gigabyte MObo
Ripjaws 2x4GB DDR 3 (1600Ghz)
MSI N560GTX 1GB DDR5
CM 430 Black Elite
AOC 20" Razor LED
SONY DVD-RW
Corsair 60GB SSD
WD Black 2TB
WD Blue 500GB
Seasonic M12II 620W
APC 600 UPS
I have already changed the UPS and the SMPS.
rijinpk1
probably an issue with smps+ups. first check with another ups if possible. or contact apc customer care to check the ups. if that doesn't fix the problem, the issue might be related to power consumption (compared to the watt delivered by the ups) since seasonic m12 line up does have problem with stepped sine wave ups with the increased load. apc 800va/1100va ups might solve the problem.
T
The Day Walker!
i was using the old model apc 600 ups,,
but due to the problem, i purchased a new apc ups.... and still the problem persists...
as for smps,
i was using XFX PRO 550 bronze edition smps, previously....
and same problem with that too....as well.....
