Power problem in Playstation 3
anuragd948
Hello. I have just bought a playstation 3 and I am facing a weird problem. I have a inverter in my home which supplies electricity when regular power goes off. The problem is that the ps3 works fine when on regular power but when regular power goes off and inverter becomes operational ps3 just switches off. I have my LCD tv and ps3 both attached to the same wall socket . The LCD works fine on both regular power and inverter but the ps3 just goes goes off on inverter power. Please help.
RCuber
The Mighty Unkel!!!
can you power up the PS3 when on inverter or when powered by inverter the PS3 doesn't power up at all?? inverters and SMPS doesnot get along very well :razz:
I suggest you buy a standard UPS for your PS3.
A
anuragd948
No , when on inverter ps3 acts as its without power. The red light does not come up so I can't power it up.
desiJATT
Away from Forums, Again!
The inverter may bot be able to supply ample power to the PS3 system for it to turn on. Try plugging ONLY PS3 in the same wall socket without the TV plug, it will work in my opinion.
A
anuragd948
thanks . i tried your suggested method and it worked :)
skeletor
Just wondering, is your inverter a pure sine wave inverter?
Edit: Good to see it's solved.
