hey folks
so ok guys last 30 days im having this wired problem my PC restarts randomly i can't predict when it happens its just so random i cant find which one causing the problem whethers its UPS Or PSU Or Main Power supply
heres my PC full specification
AMD FX 8350
Cooler Master 750 w PSU
Corsair 8 GB DDR3
Seagate 1TB Sata Drive
Cooler master Hyper 212X CPU
cooler master k380 cabinet
Dell 21.5 inch monitor S2240L
Asus strix r9285 GPU
Numeric ups 1KV
By the way its new build PC hardly 4 months hold
Soit happens during normal work / watching movies i hear a click sound [ sometimes i don't ] in my UPS then my Pc restarts at first i thought the power fluctuation caused it within 10 min it happened again then few hours it worked normal then again i got the very same problem a small click sound in UPS PC restarts
And mainly PC restarts 10 to 15 mins once[ sometimes it don't ] when the AC is running
so i took the UPS to service center the checked it they said its all fine u better check your PSU
My PSU is Cooler Master 750w PSU in the center they said PSU is also working fine
And the Electrician checked the house power supply said its power input is normal and yes your area got some fluctuations....
so i guess the time delay in changing to battery mode is causing the restart
i thought of buying APC 1 kva but after consulting with few friends they say you cant be sure coz Power fluctuation in your area is high so better go for any online Double conversion UPS
Due you guys think a online Double conversion UPS 1KVA UPS will solve this problem which is 15k [ too much for me ]
help me folks im having hard time solving this problem
AMD FX 8350
Corsair 8 GB DDR3
Numeric ups 1KV
