Power Bank 20k mAh for android devices in family below
A
amit.tiger12
Guest
Please suggest 20k mAh power bank for any android device..
for family, devices, Nexus 5, Moto e, Lenovo vibe p1m, one plus x, Huwawei honor holly, and samsung galaxy s duos..
i found many power banks... but 20k power banks prices are high, and did not found any branded 20k power.
please need help..
feature needed : not necessarily
input : fast charging (2 A)
output : 2 outputs (or 3-4 outputs) should charge device same time @ mentioned output current.. 2 output should be (2A). portable and slim design.
suggest branded if possible, local brands are last option..
please help me to find this..
thanks in advance..
satinder
DELHIITE
Better take 2 pc of 10000 mah power bank.
Mi.com.in
Or
PNY
Or
Ambrane
Power banks are good.
Most power banks showing capacity of 20000 mah are fake.
Don't even try them.
Above 3brands are good.
A
amit.tiger12
Guest
Mi.com.in
Or
PNY
Or
Ambrane
thanks.. 20k power availability in near future??
10K is not that good.
16k will be ok. if you can suggest some.. value for money and best available.
satinder
DELHIITE
Can't comment on 20k math as it is fake mostly exaggerated specs.
3brands have real juice in it.
16000 may is not in stock of mi.com/in
if you can wait, get this from here and flipkart only.
Eboy or others are mostly fake.
Beware !
Better safe than sorry !
10k mah is also not a light weight.
Also consider this aspect for portability.
A
amit.tiger12
Guest
Beware !
will this mi battery work perfectly on lenovo vibe p1m?
and other devices? because low ratings on flipkart, amazon.
yep i tried 10k battery but its not big on backup for whole family.
how to buy mi 16k power bank and from where to buy it???
rj27
Net Addict
Powerxcel 13000 mAh power bank is good for ~ 1k, available on Flipkart & Snapdeal. Do checkout.
satinder
DELHIITE
It is not in stock.
Better go for other options.
13k mah is nearby 16 k.
As others are recommending.
A powerbank can be used uoto 75% of its written capacity. If your mobile is of 2k mah, powrrbank of 10k mah will work till 75% onky means will charge only 3.66 times.
10k mah will give 7500mah of power by default.
A
amit.tiger12
Guest
It is not in stock.
Ohk. Thnks for info..
So 10k ~= 7.5k
& 16k ~= 12k
& 20k ~= 15k
Ok, do i really need this power bank??
Is it good to buy power bank?
Because i found really bad reviews about every power bank & this category is not that popular.
And now company provides big battery devices. Will it be future proof buying?
What about Power bank's lifespan?
A
amit.tiger12
Guest
The 2nd power bank has 2 usb ports, so you can avoid it, rest is your choice. the 3rd one has 6000mah more capacity than the 1st one and costlier by Rs. 700.
So 1st one is good, right?
Thanks
A
amit.tiger12
Guest
Are you using this??
Because i want good branded power bank. which will not harm my device and charge 2 or more device same time at mentioned output.
And 13k will be too small for me...
satinder
DELHIITE
So 10k ~= 7.5k
& 16k ~= 12k
& 20k ~= 15k
I am using a power bank from last 4 years or so.
When it was not a common word.
I bought 4400 mah one for Rs.2k only.
It is only 4400mah still working like charm.
Buy one of 10k mah or 13 k mah.
I have one 10 k mah of PNY from last one year.
It is future safe.
It works when you are out on a holiday or electricity is out on holiday !
LOL !
Capacity is 75 % only.
Note it down in your permanent memory.
Good power bank has a cell of 2200 math and multiple of it.
It gets heavy too.
Now new technical batteries are also coming of different type of material used in mobile batteries.
Better choose it wisely as fake ones have not good lasting charge.
I have used PNY. I will recommend it at 10,000 mah.
Ambrane is used by few friends and they reported it good.
Life of a power bank is 1000 charges. Almost 3 years.
This is for emergency use only.
Use ac charger at home or office.
Or buy car / bike charger of good quality only to save your battery life of mobile.
