Please Help Someone!!!! hardware problem.
nileshgr
I have a handycam with USB interface. The problem is that when I insert it in my computer, the computer hangs. My computer specifications are:
50 GB harddisk
256 MB RAM
500 Mhz Pentium 3 Processor
Intel Video Card 32 MB
Same problem was occuring when I used my HP PSC 1410 for either scanning or printing. But I could find the reason for it, that is a Trojan Horse in my computer. But I repeatedly scanned my computer with Avast Antivirus 4.7 with latest updates but couldn't find any virus or trojan horse.
The handycam was purchased one month ago. It is not defective and it works on my friend's laptop. It is under warranty.
Please help me.
you can email me at
nil27.9.06@gmail.com
or
nilesh.3892@gmail.com
:confused: :-(
s18000rpm
ಠ_ಠ
Give the Motherboard model .
Try scanning with BitDefender AV (on-demand scanner) in safe mode.
for the Printer, goto HP website & download updates for the Printer Drivers.
go here for Printer Problem, select "Softwares & Drivers Download"-> your OS"
i also have the same Printer & had problems in Printing word documents which had graphics (picture) in it, but a simple driver update solved the problm.
shashank4u
u can try someothere
antivirus like norton and mcfee but for yr
u must scan with those antivirus.. and then see if there were a
same problem..also check for antispyware..
nileshgr
nileshgr
Windows Xp Professional
__________
Second hand machine don't have motherboard model
__________
I have tried norton, quickheal, mcaffe, none could solve the printer's problem. Only avast could detect the virus.
s18000rpm
ಠ_ಠ
Fro Printer Problem:::
UPDATE your PRINTER DRIVER.
I've given the link above.
If you're on unlimited bandwidth (BroadBand), then run a Online Virus scan.
nileshgr
nileshgr
Anybody Can't Help?
Has anyone any solution to the described problem of hanging? I think no one has. It has been a week since I posted this problem.
:mad: :evil:
ranjan2001
From my past experience of a friend facing same problem unable to plugin any usb device, it was found that his xp pro "copy" was having a problem he formatted than HDD & got the problem solved when he installed XP pro from another disk.
He use to get BSOD the moment he connected any usb device, he too tried every thing but nothing worked.
ECE0105
Go to the Device manager and delete all the USB Root Hub entries.
Restart the computer and it would automatically get installed.
Try it then and it should work
hrushij
ur problem may be with ur hardware!!! I don't know but may work this one.
u have to clean ur slots or ur crads in cpu. it may work bcs i have face one kind of prob. with my modem when i opened my cpu cabinate i found i sours inside fixed between modem & graphoc card !!!!!!!!!!!!!!!!
