I installed PC Probe 2 which was bundled along my mobo ...ASUS p5w dh dlx.
According to the probe,
1. MY CPU FAN Speed is 1600+ and its stating it as ABNORMAL and showing it as RED ZONE alert.
2. POWER 2 Fan (Dont know what exactly this is) is running at 3k+ rpm and stating it as ABNORMAL too with RED ZONE alert.
3. MB temp is around 55+ and even that is shown as red zone alert.
What may be the reasons ?
There one more problem. When i start software PCTVi, a msg comes which says NO TV devices available. What could wrong here ?
__________
Also pls tell me what should be the ideal values for the above problems.
Thank you
__________
Are there any chances of compatibility issues with Monitor, TV tuner card and graphics card ?
If yes,
are Samsung 940BW, Pinnacle PCTV 110i, XFX 7600GT compatible with each other ?
I m still not unable to fix this TV tuner T_T
I get "No TV capture devices available for playback" msg on starting PCTV software.
__________
Someone PLS help me out with this T_T
__________
Thank you
__________
If yes,
__________
