Hi all..
I didn't know whether to put this in here or in the hardware section but I put it here because I feel it's a software problem..
I have a LAN set up on the 2 computers in my room.. Let's call them Comp A and Comp B. It used to work like a charm and I was perfectly happy with the LAN gaming and file transfers.
A while ago I installed System Mechanic on Comp A, and ran some optimisations. Since then, I have never been able to access Comp A from Comp B for file transfer. Comp A can access all files of Comp B. Gaming is also possible.
The only problem is this: Comp B cannot access Comp A at all. The error message is this: "Workgroup is not accessible. You might not have permission to use this network resource. Contact your administrator of this server to find out if you have access permissions."
I am on administrator on both computers.
I've uninstalled Sys Mechanic, but it doesn't help. I believe it's messed with some policies. I know it's the culprit alright, since another friend also has the same problem.
I've written to iolo.com but they aren't helping.
Please help me restore my LAN to working condition, guys.. You're my only hope now.
Thanks in advance,
JaX
Thanks in advance,
JaX
