Need Wifi for Meghabela Cable Broadband!!!
gohan89
I need a router for Meghabela Cable broadband.Suggest one with good range and constant speed for use with laptop,2 smartphones and also I will be using the connection on my PC.
What about this one ?
Is anyone using Meghabela Broadband here? Please suggest how to get good speed while downloading through torrents.I sometimes get 10Mbps and most times 100-200kbps even at night.
Bing
Depending on your requirements,I'd recommend an Huawei E5186(Cat6) LTE CAT6 Download Speed up to 300mbps, upload speed to 50Mbps @ 20MHz + 20MHz BW. or if you don't care too much about the max throughput, a TP-link for much cheaper.
tkin
Back to school!!
I use a Netgear JNR1010 for my Meghbela network, it works fine, I had tested it to work with 4 devices at once, range is good, configuration was a breeze.
