Inverter is not good for backup compared to an UPS because there is a gap of triggering the sensor and relay of power in an Inverter where as in an UPS there is instant triggering of sensor and relay of power. So UPS is best for a PC than a Inverter.
A sensor and relay mechanism checks whether the mains is ON or OFF in an inverter. When the mains get switched off, the relay mechanism triggers to switch from mains to inverter. Rest is same like the UPS. Because of this sensor and relay, there is a gap between triggering.
