Need to buy a PSC(Print, Scan, Copy) help required!
prateek_san
Phenom II X4 920 Owner
hey guys i Need to buy a PSC(Print, Scan, Copy) , really getting confused with HP 1608 ,HP officejet 6208 and suggest more, what will be better in efficiency and the cost of the cartrigdes. By budget is <=Rs.12000/- .....
Kindly help me guys.... u can also suggest any other companies....
tuxfan
Buy, borrow or steal Digit July 2006 issue. ;) They have compared a few MFDs (multi-function devices) in there. You will get the required info.
Tech&ME
Banned
If you are not looking at printing color pages, buy LASER MFD instead. It will be cost effective and your total running cost will come down.
ashnik
though u have mentioned ur budget, plz specify the use ie no prints per day, scans, type of printouts etc.
@ PHENOM
ya i m using the same EPSON STYLUS CX 1500...its just joy to use it...nice features in less cost...i bought it for 4.4k,
y i bought against HP was the Cartridge cost factor, HP cartridges Color cost 800-1000 but i can buy my cartridges for 250 only & HP cart r 8ml while i get 10ml in Epson, & finaly the quality is just stunning...no paper jams like HP printers hav, using it from 6 mnths..
Just go for EPSON STYLUS CX 1500.
