Need Suggestion for Protect & Safety life for Mi LED Smart TV 4A PRO 49?
shreeux
shreeux
Movie Buff
What do you mean exactly?Is kodi player able to play dolby audio files with sound?If yes then you may still need to select PCM in digital audio format setting.As long as any player can play files with dolby audio correctly in TV then it should work with that s/pdif audio convertor.
All player working, While select "Auto" in Digital Audio Format.
Kodi was working fine...Compare to other players
Kodi has inbuilt more feature settings also complicated.
That digital audio format setting is only relevant when something is connected to s/pdif port,until then you can use "auto" or "pcm" as it doesn't matter.
You wanted to know if that audio convertor will work & based on above(assuming all players working playing audio with dolby audio files) it should work at "auto" or else at "PCM".
shreeux
shreeux
Movie Buff
Yes, As of now I chose this one...192kHz DAC Converter Digital Optical Coaxial Toslink to Analog L/R RCA 3.5mm Jack Audio Converter Adapter With Volume Control
and Cable...AmazonBasics 4-Feet Digital Audio Coaxial Cable
