Need Suggestion for Protect & Safety life for Mi LED Smart TV 4A PRO 49?
meetdilip
Computer Addict
There is a cable which allows you to plugin 3.5 mm and then take the output to left and right of the speaker.
PS : No 3.5 mm audio on pro version ?
Vyom
The Power of x480
How to connect Speaker to MI TV?
a) Bluetooth Stereo Adapter Audio Receiver to Speakers (TV>>Bluetooth>>Speakers)
b) DAC (digital audio converter) (TV>>DAC>>Speakers)
A good DAC is expensive. Bluetooth speakers are not. But DAC is more robust and can give better sound output. Bluetooth can be a pit patchy.
shreeux
shreeux
Movie Buff
What is your budget for DACs.
Check out Audio and Video Hardware Recomendations and Advice.
There are two types of DACs you may buy.
DACs with Line In (L/R) or DACs with SPDIF input. Also remember Speaker DACs and Headphone DACs are targetted differently.
Also consider what kind of speakers will you be driving. Do you have amp inbuilt speakers (Active?) or do you have Passive speakers that need external amplification.
If former, you only need a DAC, as double amping is very bad. If latter, then get combi (speaker) DAC/AMP
I've never owned a good one apart from a crappy ASUS Xonar U3. Check ZReviews channel and reddit thread.
Ive heard very good things from this one in particular, if you want to be a little adventurous and not go for the regular old FiiO from Indian Amazon.
*www.amazon.com/FX-Audio-Optical-Coaxial-Amplifier/dp/B072JJT7SF
FX Audio DAC X6 HiFi Optical/Coaxial/USB Digital Audio Amplifier DAC Decoder-in Digital-to-Analog Converter from Consumer Electronics on Aliexpress.com | Alibaba Group
As of now using Swans M200MKII for my PC
Which DAC suitable for me?
Budget below 2k or 5k
I don't like to invest more on DAC...Instead of buying a new dedicate speaker set for MI-TV alone
(In my mind always ringing Swans M200MKIII for TV....I don't know its right choice or not)
shreeux
shreeux
Movie Buff
You mean quality may differ or signal may disturb frequently. Compare to regular cable connect.
shreeux
shreeux
Movie Buff
Played a few movies in MI TV- Used Both players VLC & MX poor video quality also very low sound...Switched to KODI played video was very well with good contrast and smoothly
Watched few downloaded movies in MI TV with Kodi Player. A video was the good contrast, but the audio sucks in TV speakers
Need to buy a converter pls suggest the good one, below 5k
(Yesterday watched MEG & MILE 22 in MI TV
Due to tv speakers, not enough complete movie experience)
@Nerevarine
@bssunilreddy
@SaiyanGoku
@Minion
@nac
@Vyom
@billubakra
@Gollum
@whitestar_999
nac
I don't have a clue about converter/speaker?
My assumption is that due to thin body of these LED televisions, they don't have enough space to put some powerful speakers in them.
Swans M200MKII
These are audiophile grade speakers meant for listening at close distance.
I would recommend speakers that have larger volume if you are going to use with TV (Logitech Z625).
shreeux
shreeux
Movie Buff
Yes, Due to cost & competitive, They made like this
shreeux
shreeux
Movie Buff
Swans M200MKII
Thanks for suggesting this...just reviewed in digit site....Imgur: The magic of the Internet
Already watched movies in Sony TV with Swans....Awesome..Crystal clear audio.
shreeux
shreeux
Movie Buff
*i.imgur.com/FtH4NrB.png
But they mentioned
Support PCM format, don’t support Dolby and DTS format
My queries
If I play downloaded content or any Streaming FullHD with Dolby or DTS ....The sound will not hear?
Ascendant001
It depends on whether TV converts the audio before sending it over s/pdif or whether it is doing a passthrough(aka untouched audio directly send from source over s/pdif). Check in your TV manual/settings audio section regarding this.
shreeux
shreeux
Movie Buff
Checked with TV and Manual nothing found..They simply mentioned support
Ascendant001
In your TV--audio settings see if there is a passthrough option available(it may be so that this option only shows after connecting something to s/pdif port but still try) & if yes then see if you can select the output to "raw"(untouched meaning whatever source audio is it will be passed over to s/pdif without any conversion by TV meaning convertor will have to decode audio) or "PCM"(if it is there then the convertor will work as audio output from tv s/pdif port will be PCM after TV converts any non-PCM audio to this).
shreeux
shreeux
Movie Buff
Below images are the screenshot of Sound settings.
*i.imgur.com/rpUlAqP.jpg
*i.imgur.com/CytViLL.jpg
*i.imgur.com/5zZJxDf.jpg
Ascendant001
It seems that mi TV 4A by default does not decode dolby/ac3 audio so you need to first install MX player/vlc & then enable PCM in digital audio output setting.
audio format not supported for high quality video - Mi TV - Mi Community - Xiaomi
shreeux
shreeux
Movie Buff
I select in Auto...Using Kodi Player
VLC & MX Player did not boost sound...
Ascendant001
What do you mean exactly?Is kodi player able to play dolby audio files with sound?If yes then you may still need to select PCM in digital audio format setting.As long as any player can play files with dolby audio correctly in TV then it should work with that s/pdif audio convertor.
