1. Hi Guest
    We are running a survey about laptop service in India, and we'd love your inputs. Please help us improve the quality of laptop servicing, and if you've had any bad experiences, now is the time to be heard.
    Take the survey
Need Suggestion for Protect & Safety life for Mi LED Smart TV 4A PRO 49?
Discussion in 'Peripherals' started by shreeux, Oct 10, 2018.
  1. shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
    Hi All members,
    Need Suggestion,
    For Mi LED Smart TV 4A PRO 49
    Any additional requirement to add to Protect and Safety purpose like extend life from from higher voltage power surges...Stabilizer OR UPS or Spike Surge protractor extension?
    Which one is good to add?
    @Nerevarine
    @bssunilreddy
    @SaiyanGoku
    @Minion
    @nac
    @Vyom
    @billubakra
    @Gollum
  2. Vyom
    Vyom The Power of x480
    May 16, 2009
    6,365
    231
    63
    "New" New Delhi
    I have never ever used a UPS or stabilizer for a TV.
    I think a surge protector is enough.
    billubakra and shreeux like this.
  3. billubakra
    billubakra Well-Known Member
    Dec 18, 2012
    3,464
    294
    83
    No need if you don't have electricity fluctuations at your place. If you wanna spend some bucks then use Belkin wire extender which has built in surge protection.
    shreeux likes this.
  4. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
    In my area in the summertime fluctuation more also cut off frequently.
  5. billubakra
    Dec 18, 2012
    3,464
    294
    83
    Then use that Belkin one. For backup wait for others to comment. I haven't seen anyone using a ups/inverter with tv.
  6. nac
    nac Well-Known Member
    Oct 10, 2010
    4,584
    168
    63
    As long as I remember we always used/using booster?/stabilizer for TV. In 90s it was BUSH TV, now it's BPL CRT and even with Philips 32" HD ready we're using a stabilizer.
    shreeux likes this.
  7. nac
    Oct 10, 2010
    4,584
    168
    63
    If you intend to nail the TV onto the wall, you may not have any space between TV and the wall to access ports/cables. If there is enough space, fine. If not, get a simple wall mount or if you want get an extended wall mount. Something like this
    [​IMG]
  8. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
  9. nac
    Oct 10, 2010
    4,584
    168
    63
    Yeah, I guess it should do. The one we use is smaller than this one, it's V guard don't remember the model. If I remember right, we bought it for about 1600/- 2-3 yrs back. Tata sky set top box + cable TV set top box + TV all are connected in this one.
    Check TV manual and check stabilizer manual and see how much this one can take. And also check amazon Q&A and google.
    shreeux likes this.
  10. silicon_fusion
    silicon_fusion Member
    Mar 18, 2009
    220
    6
    18
    Thanks guys.
    Today i have ordered Belkin Essential Series F9E400zb1.5MGRY 4-Socket Surge Protector (Cost 749)for my new Mi 4A PRO tv.
  11. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
    Yesterday Night Order Placed...Chose 8-Socket because of 700 Joule energy rating to provide surge protection.
    The remaining socket is less joule & sockets. Compare to this one not much price different only few 100rs only.
    [​IMG]
    billubakra and Allu Azad like this.
  12. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
    How to take Audio Output to Speakers?
    Suggest Pls
    [​IMG]
    [​IMG]
  13. silicon_fusion
    Mar 18, 2009
    220
    6
    18
    shreeux likes this.
  14. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
  15. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
    Just received...
    [​IMG]
    [​IMG]
  16. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
    Installed last week.
    [​IMG]
    [​IMG]
    [​IMG]
  17. OP
    shreeux
    shreeux Movie Buff
    Mar 12, 2012
    1,499
    111
    63
    Chennai
    How to connect Speaker to MI TV?
    a) Bluetooth Stereo Adapter Audio Receiver to Speakers (TV>>Bluetooth>>Speakers)
    b) DAC (digital audio converter) (TV>>DAC>>Speakers)
    Above both options which one is good?
    Suggest with a Product name ‍♂
    Need Urgent
    TV IN/OUT
    [​IMG]
    Speaker IN
    [​IMG]
    @Nerevarine
    @bssunilreddy
    @SaiyanGoku
    @Minion
    @nac
    @Vyom
    @billubakra
    @Gollum
  18. billubakra
    Dec 18, 2012
    3,464
    294
    83
    shreeux likes this.
  19. billubakra
    Dec 18, 2012
    3,464
    294
    83
    BTW did you ask the oem's customer support?
    shreeux likes this.
  20. Nerevarine
    Nerevarine Well-Known Member
    Feb 6, 2011
    6,446
    305
    83
    Pune
    What is your budget for DACs.
    Check out Audio and Video Hardware Recomendations and Advice.
    There are two types of DACs you may buy.
    DACs with Line In (L/R) or DACs with SPDIF input. Also remember Speaker DACs and Headphone DACs are targetted differently.
    Also consider what kind of speakers will you be driving. Do you have amp inbuilt speakers (Active?) or do you have Passive speakers that need external amplification.
    If former, you only need a DAC, as double amping is very bad. If latter, then get combi (speaker) DAC/AMP
    I've never owned a good one apart from a crappy ASUS Xonar U3. Check ZReviews channel and reddit thread.
    Ive heard very good things from this one in particular, if you want to be a little adventurous and not go for the regular old FiiO from Indian Amazon.
    https://www.amazon.com/FX-Audio-Optical-Coaxial-Amplifier/dp/B072JJT7SF
    FX Audio DAC X6 HiFi Optical/Coaxial/USB Digital Audio Amplifier DAC Decoder-in Digital-to-Analog Converter from Consumer Electronics on Aliexpress.com | Alibaba Group
    shreeux likes this.
Share This Page
