Please take a look at these configs and answer my questions.
Server PC
For this PC, two 2TB drives in RAID 1 will be use to record IP Camera feed. I chose caviar blacks for their reliability and warranty. TVS gold keyboards are supposed to be rock solid (my school has still been using the same ones purchased between 2001 and 2004, and they felt awesome when I used them-much better than my G15). Two displays, 1 monitor and 1 TV will be connected via HDMI to this system. This will also act as the server of Tally ERP.9 Gold.
Cameras will be port-forwarded for remote/ internet viewing.
Please suggest a monitor 22" that is reliable but cheap (don't need high end displays).
I need an 80Plus Gold or better PSU with at least 5 years warranty for this system. I think 300-350W will be enough. Do note this PC will be on 24x7.
This will also be the print server.
Accounts & PC
[td]
This will be the configuration of two PCs that are used for accounts and billing. Tally ERP.9 Gold client editions will be installed here. Please suggest a PSU that has 5+ years warranty and is at least 80Plus gold. I'm guessing a 300-350W PSU will be enough. These PCs will be on only during business hours. Also suggest cheap but reliable 17" monitors for these PCs.
Is the RAM I selected for both PCs covered by a lifetime warranty? If not, please suggest alternatives. The server needs two 4GB sticks of 1333Mhz Unbufferred ECC RAM and the regular ones two 4GB sticks of regular RAM.
I chose Lian Li cases because they look awesome, so don't suggest alternatives that are neither as simple-looking nor made of aluminium. I have to import some networking equipment anyway (Netgear's lifetime warranty is globally applicable), so these cases will tag along.
I will install Windows 7 ultimate and Office 2013 H&B on the three PCs.
Thanks for all the help guys!
EDIT: By popular demand, the questionnaire for the second PC
Ans: Tally ERP.9 Gold client version, Office '13 H&B, maybe some of the OS-bundled games. Firefox & Chrome will be run. Kaspersky IS or PURE will be run. IP camera monitoring software will also be installed, depending on who the camera manufacturer is. WinRAR will be run, as will some backup utilities (have to decide on which one). These are the confirmed applications, but some apps might be added in future. Sometimes all of the above will be active simultaneously.
Ans: No specific budget. Amount is as required.
3. Planning to overclock?
Ans: Ofcourse not.
Ans: Windows 7, probably ultimate, maybe pro depending on the current price difference (need Bitlocker or similar encryption so probably ultimate).
Ans: 500GB in RAID 1. 5 years warranty on HDDs is a must.
Ans: 17" highest resolution possible. Cheap but reliable is the norm.
Ans: Speakers and UPS for sure. UPS will be a big one for entire office.
Ans: ASAP.
Ans: Built lots of setups before. Same for this one. Assemblers will not get to touch the system.
Ans: Kolkata. Locally as much as possible but if online is much cheaper then no problem buying online, as long as I can get warranty.
Ans: Motherboard chipset HAS TO BE Q77 because I need RAID. Case has to be made of aluminum, so if there are cases cheaper and as well built as Lian Li ones, I'm open to buying them. PSU has to be 80 Plus Gold or higher with at least 5 years warranty. 2*4GB 1333Mhz RAM with lifetime warranty please, I like Patriot so would prefer those over other brands. I want to avoid Corsair because I've always had their products fail on me. The only time they'd work fine is when I'd get direct replacements from the company. Processor should also be an i5 Ivy. I like TVS Gold keyboards because they are built like tanks and are a treat to type with. Mouse has to be a very smooth gliding one with ~2000 DPI sensitivity. Please look at the configuration posted above. You will see that I chose the cheapest keeping all this in mind.
Server PC
Processor | Intel Xeon 1245V2 |
Motherboard | Supermicro X9SAE-V |
RAM | KVR1333D3E9S/4G x2 |
PSU | ?? |
HDD1 | WD Caviar Black 500GB |
HDD2 | WD Caviar Black 2TB x2 RAID 1 |
ODD | Cheap DVD-RW |
Case | Lian Li PC-6B |
Monitor | 22” |
Keyboard | TVS Gold Keyboard PS/2 |
Mouse + Pad | Roccat Lua + Steelseries Qck Mini |
Accounts & PC
Processor | Core i5 3330 |
Motherboard | Gigabyte GA-Q77M-D2H |
RAM | Patriot PSD34G13332 x2 |
PSU | ?? |
HDD | WD Caviar Black 500GB[td] |
Case | Lian Li PC-A-05FNB |
Monitor | 17" |
Ans: Ofcourse not.
Ans: ASAP.
