Need optional power adapter for usb hub
sling-shot
I have bought this iBall Lappie USB 4-port hub. It has a small optional power adapter pin at the back which is slightly larger than the new 2mm Nokia charger pin. (May be the older Nokia charger pin may fit here.)
The power supplied by the hub at present is not sufficient to drive a portable hard disk.
Do you know of any compatible power adapter for this so that it could power a portable HDD?
-SS
