Need Info Regarding Power Consumption
Empirial
I've an old desktop pc running Ubuntu OS and I use it mainly to download overnight and leave the monitor switched OFF. By looking at the specs of my CPU can you tell me how much electricity it consumes?
Specs :
Intel Core 2 Duo E6300
NVIDIA 7300LE GPU
500GB 7200 RPM HDD
305W PSU
Bsnl Broadband Modem (Basic Siemens Model).
Regards.
patkim
while my post does not give you the answer you are expecting, I can suggest you to also explore various websites that provide similar info about the PSU capacity / power consumption based on input parameters being components of the system. What I think is it's also important is to know the % Efficiency of your PSU that also needs to be factored in to find the actual input power drawn from the mains.
Specs :
NVIDIA 7300LE GPU
500GB 7200 RPM HDD
305W PSU
Regards.
My hunch is ~110 - 115 watts. BTW, get yourself a raspberry .. you will save a lot more power.
