Need help with Need for Speed Underground 1.
S
spykids_666
Guest
hi guys,
does any one know how to take backup of the progress done in the Need for speed Underground 1. i cant seem to find the "save data" nor the the progress data in this game. please help me.
Thankyou.
S
spykids_666
Guest
Sourabh said:
check ur MY DOCUMENTS folder
i dont want the save data of Need for speed underground 2.
i need save data for Need for Speed Underground 1. the save data is not there in my documents.
Thanks Anyways.
SpYkId 6^6
shwetanshu
Dude first of all u shud have mentioned ur OS. Anyways i know it only for the XP.
Well b4 going for the save files, u must enable SHOW ME HIDDEN FILES. then follow the path:
c:\Documents and Settings\All Users\Application Data\NFS Underground.
Hope this solves ur prob, if using any other OS, do a little bit of GOOGLE. Bye !!!!
