preethesh.shetty
hi guys,
I've finally decided to get a decent cabinet coz of all the heating problems.
After a lot research I've narrowed the choice to 2 cabinets.
Thermaltake Matrix
Coolermaster Elite 330
So do any of you know about these cabinets? Would you advise me to buy from these (if yes which one?) or would you suggest any other.
I've found out that both these cabinets do not come with PSUs. I'm currently using a Techcom 450W PSU. I'm not sure if this PSU is good enough for my config. (Core 2 Duo E4300, Intel DG965RY, Nvidia 8600GT, 2 Optical Drives, 250 GB HDD, 3GB Ram). I'm guessing its not as I'm getting a LOT of problems with heating and dust. So I would need to buy a good PSU as well. I have no idea about PSU's. So please suggest anything good for my config.
My budget for both cabinet + PSU is Rs. 4000/-. I might be willing to shell out an extra 1K if it is reqd. But I would be more inclined to spend the extra cash on the PSU rather than the cabinet.
Also, both these cabinets come with only 1 Fan. So I would need to buy another fan. Please also suggest a suitable inexpensive fan.
If possible please also let me know where I could get these in Bangalore.
Thanks,
Thermaltake Matrix
Thanks,
