Need an IPS led monitor 23" or 24"...
sam222
I'm planning to buy a monitor.I heard that IPS are superior in color reproduction..So i need your help choosing good IPS monitor...I do a little bit gaming so suggest the one which is having low input lag...And also tell me the difference between HDMI and DVI and which one to choose and why ?
My budget is 15k..
iampears7
Re: Need an IPS led monitor 23" or 24"...
i have the same Qs.. I suggest you to go with Dell S3240L / S2440L under 15k or Dell U2412 or U2312 Under 20k..
Search on flipkart.
Search on flipkart.
