gmg9
in the kaya
Do you need this ? -
Intel® Virtualization Technology for Directed I/O
I'm assuming that you need vt-d and vt-x. Now first of all I'll not recommend fx bulldozer processors . They are a failure (leaving 4core ). Getting 2nd or 3rd gen intel i5 will be a far better choice. Now is this right ? - 22k ->psu,mobo,cpu and ram
yes. i need both vt-d and vt-x.
but with amd cpu, i can run more than 5+ VMs at the same time without any prob or lag. and as intel i5 with 4 cores, i can run maximum 3-4 VMs at the same time. i am still reading some article n reviews on virtualization intel vs amd..
22k > cpu,mobo,ram,cabinet+psu.
and also i was not aware dat i hav to buy a seperate coolong system fr the cpu also
amd fx processors don't have integrated graphics like intel.it is there in their mobos.also read this because it may not be a good choice for you to go with intel for virtualization.
[Phoronix] Ubuntu 12.04 KVM/Xen Virtualization: Intel vs. AMD
will look in to that. thx..
One more thing , no "k" processors have vt-d so , here you save on cpu cooler and mobo
Now these are the processors with both vt-x and vt-d -
i5-2400 , i5-2500 , i5-3470, i5-3550,and i5 3570 (I've not mentioned p processors because they have integrated gpu and also which are not in the list are s and t. They save power but go down in performance ; not significantly )
Now that there are no k processors , get a mobo around 3-4k as there will be no overclocking
ok .. thx..
one thing i dont understand, wats exactly wrong with this AMD cpus. why people dont still recomend them. is there really anything wrong ??
as in my case, i was looking at the cores which i will be needed for VT. but hav read some reviews where they also suggest to go with i5 2500k. dont get it
