[need advise] building my box [first phase] @ 20-22k
gmg9
in the kaya
hi friends...
first the template Q n A..
Ans: 1. software development/compiling (like for android, linux etc.), android aosp etc.
2. intense virtual machine (linux,windows,osx 32/64 bit) works where linux will be as host OS always.
3. gaming (i actually hav no idea about the latest games n their needs). bt will love to play some good multiplayer/fps game on single machine or on network with joysticks. bt i dont want to play hi-fi games which needs good/expensive h/w.
4. running servers (apache,ftp,nfs,dns,dhcp,ldap,iis etc..)
5. run s/w like ms office, gimp,vlc etc. watch movies also.
Ans: 20,000 INR. can be extended to 22,000 INR. my idea is to buy components one by one. so am not in that hurry.
3. Planning to overclock?
Ans: yes, if possible and comes within budget.
Ans: there will be two host OS (dual boot), linux n windows 32/64 bit (7 or server2008 probably). but will also run linux/unix (centos,freebsd,solaris etc.). windows (xp,7,server). osx.
Ans: will buy it later. may be 500gb.
Ans: yes, will buy a monitor. and for size and resolution, whichever comes within budget with good support n warranty.
Ans: UPS ( i hav a old microtek with excide 600v battery ups), graphics card.
Ans: within 2 month.
Ans: yes. this time also i will try to asamble it myself. but am not that tech person.
Ans: kolkata. wherever i get cheap price n good support, i will buy. but i also prefer to buy on EMI. so i am open to buy from online shops also. (like for monitor- i was looking at dell. they offer buy on EMI)
Ans: right now i want to buy the main components. cabinet (with smps), cpu, motherboard, ram, monitor. i will buy others one by one later.
so my budget is 20-22k for first phase. right nw i want to buy :
Cabinet (with SMPS):
PSU: not sure
CPU: those with good virtualization support
MoBo:
RAM: 4gb
Monitor: which ever comes within budget.
my few queries:
1. do i need a cooling system ??
2. do i need a seperate PSU ? is there will be any prob if use the smps comes with cabinet ?
3. as i will do virtual machine works, wat will be best CPU for it ? i hav no probs to go with AMD if it gives good performance?
4. do i need a dedicated graphix card? as i will be running win7 n some games (not in my priority list).
5. i hav a IDE samsung 80gb internal hdd. will modern latest mobo supports ide hdds ?
thx a lot to u guys in advance. will really appreciate if get advise n help from u guys. :)
you need a cooling system if you are overclocking.
you definitely need a psu.smps which comes with cabinet are usually of crap quality & meant only for low power systems.(also see this *www.thinkdigit.com/forum/power-sup...89-power-supply-blacklist-thread-newbies.html )
don't know the latest scenario but if you have the budget intel quad cores are really good.
if you go for intel the integrated graphics within processor should be sufficient for your usages.
no modern mobo comes with PATA port so you have to either buy a usb casing or pci sata+pata card.
acewin
Point Blanc
what does first phase will include. and 20-22K for everything including monitor will make your config quiet weak.
and buying one by one or in EMI helps you increase the budget by any means ??
gmg9
gmg9
in the kaya
no modern mobo comes with PATA port so you have to either buy a usb casing or pci sata+pata cardnatna.
thx whitestar_999 for ur reply :)
i am not dat into overclocking. so its like "if its possible, will do it". overclocking will not help me on this much.
psu will cost xtra. how can i buy a decent cabinet+psu within 2000-2500 inr ??
thx for the guide link. will look into that.
yea, as i will not be buying seperate graphics card, may be i will go for intel. but then amd cpu has good virtualization support with low price.
i hav that extarnal usb cashing. but i want to use as internal hdd. lets see... thx..
thx acewin for reply.
yes, u r right. if i include monitor then my rig gonna be weak with low-end cpu. so i will exclude monitor if its not coming within budget.
mainly i will buy cpu,ram,mobo,cabinet.
if i get all on emi, i may increase my budget.
gmg9
gmg9
in the kaya
is it really not possible to build a rig within my budget acoording to my needs ???
gmg9
gmg9
in the kaya
Ask just a week or so before buying system..
wat difference does it make ?
i will be buy the whole rig within nxt 2 month of time, not after 2 month. right now i will be buying those main components within nxt 2 weeks..
i need ur suggestion mainly for the proper CPU n MoBo. cause i will be using my box mainly for virtualization. 4-5 VMs (may be more) will be running at the same time on host os (linux).
save some more & buy better components instead of buying now & regret later.the usages you mentioned require at least a quad core for smooth performance.
gmg9
gmg9
in the kaya
i hav no problem to go for quad core. bt i wont buy i7. dats beyond my budget. but i can invest in i5 type cpu if its really worth it.
and dats why i needed ur suggestions.
amd fx 8120/8150 looks best for your usages but these will cost ~9500 & 11500 respectively.also you will need a good mobo costing ~6500 to fully utilize these processors.many such boards don't come with integrated graphics so adding a cheap graphics card(radeon 5450) for ~2000 & this combination alone will cost you ~18000 minimum.
gmg9
gmg9
in the kaya
yea.. if i go for amd i hav to buy a seperate gfx card. this cpu looks good to me too. but do i really need a 8 core cpu?
4-6 core will be good for me ,i guess. is there any good intel cpu for that ?
plz also suggest a good compatible mobo for da cpu. and wat cabinet n psu i will go for ?
if you limit your usage to 3vm at a time then intel i5 can do the job(3 cores 1 for each vm & 4th core for host os).but the thing is cheapest i5 will cost ~9500 too but you can get a ~4500 mobo with no graphics card required.so you will save ~4000 compared to amd config but will be limited to 3VM & 1 host os for smooth functioning.if that's ok with you then go for i5 2400/2320(whichever is cheaper)+gigabyte GA-B75M-D3H+2*4gb corsair 1333 ram.
gmg9
gmg9
in the kaya
after reading some reviews .... (prices r frm FK)
amd fx 8120 = 8 cores. NO integrated gfx [10k INR]
amd fx 8150 = 8 cores with Integrated gfx [12k INR]
both can be overclocked (which i may not do). BUT for both, i hav to buy a good cpu cooling system which will cost me another 2k.
and if i buy 8120, then again i hav to buy a separate gfx card. cheapest good decent will cost me 3-5k.
now am not sure how good is the 8150 inbuilt gfx n its performance... can u guys hav any say on this ??
wat abt FX 6100 = 6 cores with integrated gfx [7900 INR] ??
intel i5 2320 = 4 cores with Integrated gfx (no overclock) [11k INR]
intel i5 2400 = 4 cores with Integrated gfx (no overclock) [11700 INR]
intel i5 2500 = 4 cores with Integrated gfx HD 2000 (no overclock) [12600 INR]
4 cores and with integrated gfx. NO overclocking (i dnt bother). not sure if i hav to buy a seperate cooling system !!
so if i go with this CPUs i dont need to buy a extra gfx card which will save me around 3k.
intel 2500k = 4 cores with Integrated gfx HD 3000 (overclock-able) [13500 INR]
only advantage is, its overclockable. good integrated gfx.
my main need is virtualization, and then gaming.
plz suggest components, according to the CPU. this will help to choose the best possible rig for me. PLZ dont bother abt the budget. i may increase it.
CPU: amd fx8150
MoBo:
RAM:
GFX:
Cabinet:
PSU:
Cooling system:
any other:
CPU: amd fx8120
MoBo:
RAM:
GFX:
Cabinet:
PSU:
Cooling system:
any other:
CPU: intel i5 2400
MoBo:
RAM:
GFX:
Cabinet:
PSU:
Cooling system:
any other:
CPU: intel i5 2500
MoBo:
RAM:
GFX:
Cabinet:
PSU:
Cooling system:
any other:
thx a lot for all your help frnds. getting really good info n help from u guys...
Chaitanya
CPU: amd fx8120
MoBo:
RAM:
GFX:
Cabinet:
PSU:
Cooling system:
any other:
2.Gigabyte GA-880GM-USB3 Motherboard | Motherboard | Flipkart.com@5.1k
or
Biostar A880GZ Motherboard | Motherboard | Flipkart.com@3.6k
3.G.Skill NT DDR3 4 GB (1 x 4 GB) PC RAM (F3-10600CL9S-4GBNT) | Ram | Flipkart.com *2 @ 2.5k
4.Avoid for now gather ~5k for HD 6670(SAPPHIRE HD6670 1GB DDR3 128-bit 6670 PCI Express 2.1 x16 HDCP Ready Graphic Card)
5.Cooler Master Elite 311 Mid Tower Cabinet | Cabinet | Flipkart.com@2.25k
6.Corsair CMPSU-430CXV2UK 430 Watts PSU | Psu | Flipkart.com @ 2.9k
hitesh
Do you need this ? -
Intel® Virtualization Technology for Directed I/O
I'm assuming that you need vt-d and vt-x. Now first of all I'll not recommend fx bulldozer processors . They are a failure (leaving 4core ). Getting 2nd or 3rd gen intel i5 will be a far better choice. Now is this right ? - 22k ->psu,mobo,cpu and ram
amd fx processors don't have integrated graphics like intel.it is there in their mobos.also read this because it may not be a good choice for you to go with intel for virtualization.
[Phoronix] Ubuntu 12.04 KVM/Xen Virtualization: Intel vs. AMD
hitesh
@whitestar
Guess I should have been more clear . When I said that getting i5 will be a better choice , I meant to say the one which support vt-x and vt-d both for which I had asked for op. Now the link you have posted has the comparison b/w an i7 without vt-d. vt-x can be found in almost all new proccys but vt-d is found only in specific processors
gmg9
gmg9
in the kaya
or
thx :) noted..
hitesh
One more thing , no "k" processors have vt-d so , here you save on cpu cooler and mobo
Now these are the processors with both vt-x and vt-d -
i5-2400 , i5-2500 , i5-3470, i5-3550,and i5 3570 (I've not mentioned p processors because they don't have integrated gpu and also which are not in the list are s and t. They save power but go down in performance ; not significantly )
Now that there are no k processors , get a mobo around 3-4k as there will be no overclocking
