Microphone problem in HD audio
nishant_nms
I have a ASUS K8N-VM motherboard it fearures Analog Digital AD1986A High Definition audio. The problem is that the microphone doesn't works when I connect it to the rear port. But when I connect front pannel(AC'97 compliant) audio cable to the board then microphone works from front port but still it doesn't works from rear one. Help me thanx in advance.
nileshgr
nishant_nms said:
the microphone port works as the centre and subwoofer port in 5.1 channel and it makes sound
You mean to say that your Mic, Speaker & Woofer is on the same port? :)
nishant_nms
nishant_nms
hey man the mic doesn't works in 2.1 mode and in 5.1 mode mic is not availabe. Haven't u used it ever(onboard 5.1)
nileshgr
Buddy, i have an old pc. Not p4, its p3 here. :)
narangz
Web developer
try doing this:
go to master volume(speaker icon near clock)
click options and select advanced controls
under the mic slider click advanced. if it has an option 'front panel microphone' selected then de-select it.
nishant_nms
nishant_nms
@narangz thanx man it worked
repped u
__________
One more thing is Azilla HD compliant front panel connectors are available in market?
__________
any one using Azilla HD compliant front panels
__________
One more thing I also face a problem of noise in audio like when u recive no signal on TV. But when I uninstall the audio driver of Mobo and use default Microsoft driver it works fine. Any other pepole using ASUS K8N-VM face such problem or not. Plz post
__________
anybody there
__________
bump..
nileshgr
repped u
__________
__________
__________
__________
anybody there
__________
bump..
Do u mean to say that hissing sound on the TV when there are ants running all over the TV? :)
narangz
Web developer
Did you try installing latest audio drivers? Maybe it'll help. Also if you have any TV tuner card then update its driver & viewing application.
Well if you find Azilla HD compatible frontpanel do let me know :)
nishant_nms
nishant_nms
@The Unknown ya the same sound.
@narangz I have got latest drivers and I have no TV Tuner. I am not able to get tha Azaila compatible front pannel in my city so I was asking whether it is available in other cites or not
It works normal in Windows XP x64 Edition.
NikhilVerma
I have the exact same problem but weirder!
I have the same mobo ... K8N-VM ... with Analog Digital AD1986A High Definition audio but in Windows Vista it thinks that my card gives gives digital output ... But I want it to work the analog way ! As I don't hear any sound currently from it ...
But when I try to install my audio drivers for windows XP ... I get sound from only the front two speakers .... I have a 5.1 speaker setup.
Has anyone found drivers for this card for Vista ?
NikhilVerma
Your mic won't work in 2.1 mode either .... the .1 is for subwoofer... on which u connect ur microphone ... so to get microphone working on rear port set your audio to 4 channels and then try it.
nishant_nms
nishant_nms
@NikhilVerma I have got my that problem solved.
I was asking about the buzzing/hushing sound
__________
You need the file AudioAD1986A6100-Vista.zip. It is in the download section (but not under our MB).
NikhilVerma
even I get that hissing sound when I am playing a game and then I press Alt+Tab.... dunno how that comes
And can you plz gimme the direct link to the drivers for Vista ? I have analog speakers .... and I need 5.1 Audio in my vista installattion ...
Which download section you were talking about ?
