harshilsharma63
DIY FTW!
If you fear your creation will cause damage, them do more research before building one. And as kartechnology  has mentioned, your psu will shut it down itself.
			not wires and stuff but if something goes wrong my whole i7 rig will be burnt to ashes............
Same fear here also.
SO guys i still haven't got down to the LED inside the cabinet. Went out to buy LED's they werent giving less than 5 mtr n also the quality i wasnt sure of. Maybe will give it a try on d coming weekend and if it works out well then fine otherwise will buy the nzxt hue. :/. I'm just worried about the quality of the LED strips. :/
Why don't you get it from eBay? I had purchased this one:
5M 5 Meter LED SMD Strip Light Warm White Blue Green RED 3528 60 LED Meter | eBay
why are those ebay link not working for me...........Why don't you get it from eBay? I had purchased this one:
not working for me idk why when i click on it it redirects me to ebay site.........it works fine.
in local shops in hyderabad you get for 100-125rs....
Hehe. Good thing I used the 100/- off coupon then..
Search for 'LED Strip' on eBay, and you will get it.
giv me coupons
will get a rgb led...
I have bought a BLUE LED Strip from ebay and got it soldered to a 4 pin MOLEX connector but the guy who have done it do not know which is + or - values on the LED strip.So if I connect it to my PSU will it damage it in any way?
