LCD monitor Flickering :(( problem
max_demon
IM AS MAD AS HELL!!
Earlier on my pc i was useing DVI-D cable for my monitor (T2200HD Benq) running at 1920x1080p then everything was fine , but recently when i needed DVI-D cable for Playstation 3 i have to choose VGA .
i started noticing that the screen is flickring like CRT monitors . the refresh rate shows 60Hz at 1920x1080 .
I use nVIDIA 8400GS non overclocked
are there any problem ?
Disc_Junkie
Call me D_J!
Some times forcing the resolution leads to decrease in refresh rate which is not good and stresses the monitor. Better shift it to a lower resolution.
Cool G5
Also make sure the card is getting proper supply of fresh air. A problem with heat dissipation can cause similar issues.
max_demon
max_demon
IM AS MAD AS HELL!!
also my ps3 from DVI or even PC connecting from DVI works Perfectly . it only happnes in VGA
The Sorcerer
oh wow...Xenforo!!!
^^ It should. Playing high def is another story.
@ max demon: Based on what you said, issue is on the VGA. Try to borrow a vga card and see if you are getting the same issue from there. If you are not, the flickering vga needs to be fixed.
