hi all.
i converted a .dat file to divx using dr divx 1.06 but after some mins the audio is not in sync with the video . which is nost undesirable . i have tried using river past video cleaner to some success. but sometimes it is unable to convert the entire clip and converts only the starting few sec or minsof the video...... different each time for the same video clip .while some videos are done properly without any problem .
your suggestions and adviec and corrections are sincerely needed.
manmay
manmay
