kool
Hi guys,
I am using BSNL broadband with Siemens modem + TPLink WR740N wifi router in my flat. I have also other flat at the same floor but distance is 40-50 feet from my flat.
I think buying LAN cable gonna cost me more and also not suitable for wiring. In a row there are 3 flats. and my FLAT is 101 and 103. There is neighbour's flat (102) in between 101 & 103.
So what should I buy to extend wifi range to my other flat (103) from (101) ?
Should I buy Tenda A301 repeater or TENDA N301 router (can be used as repeater also).
Which of the above two device will give stable and long range of wifi signal ?
*www.amazon.in/Tenda-A301-Wireless-Universal-Extender/dp/B00LV2UKK6?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=dd22164e-f1ab-4097-a350-095f39ce6b2e
*www.amazon.in/Tenda-N301-Wireless-Setup-Router/dp/B00D3GO8R4?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=dd22164e-f1ab-4097-a350-095f39ce6b2e
