How do i use my interent speed among my devices using wifi?
rajesh00
I have 2mbps internet connection to my desktop pc.I want to use these speed to my laptop and my 2 Android devices.I heard it can be done by wifi.So suggest a cheapest best wifi device..And mentioned how do i setup it(i'm a beginner :( )
Kev.Ved
Buy a wifi router. Buying guide you can refer previous threads/else someone else can cover that for you.
Setup:
Connect the LAN ethernet cable from your modem (which is currently connected to the desktop) to the router. Power ON the wi-fi on it. Connect one LAN ethernet cable from it to your desktop. Laptop+mobile devices will gain internet access from wi-fi. IP addressing: Leave dynamic IP addressing enabled on the router.
rajesh00
rajesh00
Setup:
Thank you mate !!
