Scott274
My SMPS and motherboard CPU fans are ok but the third cabinet fan at the back (below SMPS) makes a lot of noise.
Can anybody suggest any lubricants which can be found easily in a home. My sewing machine oil just got over. But I have some parachute oil and cooking oil, will any of them do..
And if I use oil how many drops to put in the fan after removing the front fan seal and should I keep it around or immediately put the seal back on and reinstall the fan in the cabinet.
If you suggest any other home lubricant then please advice also on how to apply it.
