[HELP] PROBLEMS using Fedora 7
suhas_sm
Today i installed the Fedora 7 provided by digit in july issue. Installation executed smoothly. I am using linux for the first time.
I was trying to mount windows partions. Tried a lot to mount. Read guides and tutorials online. But its not loading. Could there be a problem with the OS ? Or its just me ?
Nothings happens after i issue command in terminal. Cursor moves to next line and keeps blinking.
Just for confirmation could u tell me how to mount ?
sda1,sda5,sda6 are my window based partitions and sda8 is my linux.
QwertyManiac
Commander in Chief
If cursor moves to the next prompt without an output, it means your command was successful.
What File System are your partitions, FAT32 or NTFS? I can write a small script to ease your work if you let me know that.
