Poltergeist
Greetings,
I own a monitor,somewhat new i guess.
The Problem.
For the past few months i am having a slight problem with my monitor.
Whenever i boot the system the display on my monitor covers only 8 inches at the centre of the screen.
The display is bent towards the inside like a concave lens at the edges.Also it keeps on flickering at the edges.
The right side is blank so is the left side.I cannot use the monitor controls to expand the display.
What i have noticed is that after a few minutes the display flickers for a few minutes and then automatically covers the whole screen.
But sometimes i have to bang on the table where the monitor is kept for it to cover full screen.
What I Have Done.
As i said before the problem starts when i boot my computer so i dont think the BIOS is at fault,and i also installed a new OS but even then the fault persists,so no driver problem there.
Then i removed all the wire connections,moved all the electronic devices like mobile etc, and then just connected the monitor and the power cable,but to no avail.
Any help\suggestions welcome.
The Problem.
What I Have Done.
