Help Need Urgently (WinXP user Problem) i am in a big trouble...............
satyamy
Alive Again...
My Frnd has a HP Pavillion dv5000 Laptop
His internet was not working so i tried something to repair it
& i also
I opened "Control Userpasswords2" & found it has 3 users
1) Administrator
2) Sanjeev
3) ABC
at that time currently sanjeev was logged on
but i deleted both the account sanjeev & abc & tried to delete administrator but it did'nt deleted
& restarted the machine
Now after restart i tried to login from Administrator
but it says error something like user added for deletion
& also i tried to login from other 2 but got the error check password or domain name not present
Now i am unable to login to PC
i also tried Administrators & Guest but it didnt work
It has 2 drive C=30GB & D =5gb
C has winXP loaded & also has data in it D also has important data
so i cant format the laptop
can anyone tell me if i can make a New User ID from Dos so that i can login in
Pls help
His engineer says he has to format his laptop
My friend is shouting on me & blaming me for this
Pls tell me the ways to secure the Lap
I know that it is possible to change admin password using "net" Command is theri any command to make a New User "Net"
Pls help
Pls help..................................
sakumar79
1. Try system restore
2. Try logging in through safe mode
3. Boot with XP CD and try to repair the install
Arun
suraj
& i also
1) Administrator
2) Sanjeev
3) ABC
Pls help
Pls help
friend as u deleted all the userlike "sanjeev" and "abc" . there was no need to trying to delete administrator user account when u were logged on through sanjeev.there is possibility of deleting some "windows " files ,so that it may ask for restarting .first switch off the system and restart after some time ,if it restarts successfully then logged on as safe mode ,if still failure then place ur win xp cd and configure through "repair " when installing ask for .other wise take out ur hard disk and attached another system ,,and accesss ur old file and folder what u need.
satyamy
satyamy
Alive Again...
It is possible from command prompt to make a new user
code is
net user **** /add
(in place of **** type new user name you need)
But this only works if you are logged on
If I try repair & then go to command prompt from it
this Net user command dosent support
Pls help me
tell me the possible way to make new user name without logging into WinXP
suraj
code is
net user **** /add
Pls help me
IT may not possible to create a new user through command prompt without loged on xp ,,, i think so........
s18000rpm
ಠ_ಠ
when you repair the XP Installation, DO NOT USE the RECOVERY DISKS. (which comes with HP Laptop)
they dont give you the option of repairing:wink:, better use your XP CD (non OEM).
didnt the "System Restore" work???
if re-installation is your last hope, then pop-in the Recovery Disk, & select Standard Recovery.
the Standard Recovery WILL NOT DELETE/FORMAT any files. it'll only delete the system files (during XP installation).
