Help need a MotherBoard for i3 530
ajithpj2005
Hi techies at digit
I am new to digit. i would be very happy if you could help me with an answer.
Which is the best MB that comes between 5-6k with integrated Graphics support from Gigabyte or Asus that support an i3 processor. :smile:
Also i would need a 2 GB Ram. Could anyone update me with the prices for Corsair.
Thanks in advance
saswat23
Re: Help need a MotherBoard for i3 350
For mobo options are:
Gigabyte- GA-H55M-UD2H - 4.6k
MSI- H55M-E33 - 4.5k
MSI- H55MA-E43 with usb3 n sata3 - 5.3k
And a 2gb ddr3 ram would cost around 1.2k of any brand.
J
Joker
Guest
ya..
compared to core i3-530, AMD athlon II x4 640 is much better. better onboard graphics too. 4 cores.
A
ajithpj2005
Thanks a ton guys. @ saswat, Gaurav ; thanks a lot for the information.
Sorry that i wasnt able to check ur replies for some time. @Ishu; Now as you guys have suggested i m looking for the price for AMD Athlon II x4 here in kerala. If anyone could help with an update i would be very thankful
Thanks & Regards
Ajith
A
ajithpj2005
Thanks a lot guys. I think i have got all the info that i needed. Now let me get the machine up. Cheers to all !!!
