Help me solve my pc problem
samprince1991
My sytem config is
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Name USER
System Manufacturer INTEL_
System Model ECG3510M
System Type X86-based PC
Processor x86 Family 6 Model 23 Stepping 7 GenuineIntel ~2319 Mhz
BIOS Version/Date Intel Corp. ECG3510M.86A.0112.2009.0203.1136, 2/3/2009
SMBIOS Version 2.4
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
User Name USER\welcome
Time Zone India Standard Time
Total Physical Memory 2,048.00 MB
Available Physical Memory 904.61 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.94 GB
Page File Space 3.84 GB
Page File C:\pagefile.sys
and i had Nvidea gfrorce 9800 graphics card.
and my system was working fine.
once my 500 gb harddisk burst.
so i sent it to the company to replace it and they did it.
THEn my pc was dead slow.I REINSTALLED XP AND I did not solve my problem.
So i sent my pc again.
THey did something and they said that the graphics card failed and so they removed it.But the graphics card is fine(I gave it to the store where i bought it and tested it) Now they returned the pc with kaspersky antivirus(original) installed on my pc .
Now my pc is working fine ,but when i try to install any software it hangs for a large time and returns to the original condition.Is this due to antivirus os does my hardware has any problems?
Give some ideas to what to do with that graphics card?
coderunknown
Retired Forum Mod
My sytem config is
System Name USER
SMBIOS Version 2.4
little insight into your pc config will help. processor, motherboard & powersupply, along with brand, model number & wattage.
gagan007
Uhu, Not Gonna Happen!
Proccy is Intel Core2 Quad CPU, 2GB RAM, MOBO most prolly Intel Desktop Board DG35EC... :-|
I can't tell using which s/w he has pulled all these scary specs
@OP: Which HDD did they give you next? Why don't you try putting the graphics card back in your machine and see if it works...anyways even if it is gone it will be no harm for your MOBO...
asingh
Remove your LAN cable / or internet connection device. Uninstall the anti virus and check. Also post a screen shot of the task manager, with the process tab expanded. We should be able to see ALL the processes.
rhitwick
Democracy is a myth
HDD burst???!!!
Burst means? Can you please tell what exactly happened with the HDD?
And, if KIS is installed and advanced settings is activated, then any file you try to open which is not whitelisted in KIS, KIS would first scan it then it would let you open it.
And I see ur virtual memory size is as same as ur RAM, try increasing it, try 4GB and revert back here.
S
samprince1991
They gave me a new HDD
---------- Post added at 07:14 PM ---------- Previous post was at 07:13 PM ----------
Ok I will try ,But if this works ,is my antivitus a waste?
---------- Post added at 07:23 PM ---------- Previous post was at 07:14 PM ----------
HDD burst???!!!
i Have tried this but still it hangs while installing
---------- Post added at 07:33 PM ---------- Previous post was at 07:23 PM ----------
Ho do i find all these in a single click?
gagan007
press Winkey+Pause|Break key....
iinfi
mekalodu
open ur cabinet and using a vacuum cleaner blow air into it to clean it .. blow air into the smps also .. rear fan ...
