help buying a pc cabinet
forcooler
hey cud sum1 suggest a nice (not very expensive) cabinet
i had a good one(without any fans tho),but now that got a nvidia 8800gt i need better air flow,cooling etc
also if anyone's from pune cud they tell me where i cud get one??
thnx in advance
Choto Cheeta
Rebooting
welcome to the forum...
It would be really nice if you can mention your budget... !!! :)
thank you..
mean while, visit this links, all most of this bellow ones are available in India...
*www.zebronics.net/cabinets.asp
*iball.co.in/inner/show_product_details.asp?catid=20
*www.coolermaster.com/products/product.php?act=category&tbcate=17 << the most expensive ones and bit hard to obtain...
refer here, *www.thinkdigit.com/forum/showthread.php?t=8673 post there see if any one from your place can direct you towards a right place :)
Harvik780
ToTheBeatOfUrHeart
I would also like to suggest that you can cool your 8800GT buy forcing FAN rpm level to 85% all the time using either riva tuner(Single) or ntune(Single/SLI).
Currently due to some reason,the 8800GT GPUs run at 39% Fan Duty cycle all the time even at full load thus the high temps.Forcing fan duty cycle to 85% will not harm the card in any manner.
F
forcooler
my budget is max 3500,the cheaper the better,anyway shud i really insist on a front fan??
i'm getting a case for Rs 1350/-, with two fans in the side,one at the rear(all fans 60mm),but no front intake fan,but yeah the front grill is pretty open(even without a fan)
i'll try ntune
Pathik
Google Bot
Get a zebronics Bijli or Antibiotic
*www.zebronics.net/gamingcabin.asp
Or a Ammo 533 *www.zebronics.net/ammo_533.asp
F
forcooler
thanks abt the ntune tip,it worked,GPU temp has come down by 5-7C...
anyway i'd love a zebronics cabinet,but can't seem to find a pune contact no.,the one listed on their site doesnt work!!!
what abt the case i mentioned??
